Ai Agents course error in running the Smolagent example
Hello, following unit 1, in the AI agent course, running the given application built in smolagent below. The question is time in EST now?
Any ideas? what am I missing here.
Final answer:
Error in generating final LLM output:
422 Client Error: Unprocessable Entity for url: https://api-inference.huggingface.co/models/Qwen/Qwen2.5-Coder-32B-Instruct/v1/chat/completions (Request ID: Zji2Dy1jhRHQ_jjXJLqQx)
Input validation error: inputs tokens + max_new_tokens must be <= 32768. Given: 89942 inputs tokens and 2096 max_new_tokens
Make sure ‘text-generation’ task is supported by the model.
The error message says that the input tokens are too large and exceed 32768 (-2096), so it can’t be processed, but if this is the result of following the course, then it’s a bug in the course in a broad sense…
If possible, why not try changing the model?
Or raising issue?
I am having issues while running the agents using HfApiModel(). Following is the syntax and the error:
from smolagents import CodeAgent, DuckDuckGoSearchTool, HfApiModel
Initialize the search tool
search_tool = DuckDuckGoSearchTool()
Initialize the model
model = HfApiModel(hf_model)
agent = CodeAgent(
model = model,
tools=[search_tool]
Example usage
response = agent.run(
“Search for luxury superhero-themed party ideas, including decorations, entertainment, and catering.”
print(response)
Error in generating model output:
402 Client Error: Payment Required for url:
https://router.huggingface.co/hf-inference/models/Qwen/QwQ-32B/v1/chat/completions (Request ID:
Root=1-67eb90ed-4dceeaaf55ae88031ef4b296;dc2390e1-cf09-4f27-b530-c55bff8d2db7)
You have exceeded your monthly included credits for Inference Providers. Subscribe to PRO to get 20x more monthly
included credits.
I know that it is asking for upgrading HF subscription, but is there any way I can use it for free? I am a beginner at HF
That’s just a simple case of exceeding the usage limit, so it’s a bit difficult, but I think you could get around it by using a local model or using another company’s API.
The only way I got around this was upgrading my HF account. I know that’s not the ideal solution, and not something that should be the easiest path forward, but I guess you can downgrade your account after the course is completed.
Yes, most of the errors disappeared once I upgraded my account. Looks like a capacity issue ( Token counts aren’t being properly returned from the model API).
Although, I did make some changes to the Gradio_UI.py file to resolve some Type issues - similar to the below
Before
total_input_tokens += agent.model.last_input_token_count
After (add safety check)
token_count = agent.model.last_input_token_count or 0
total_input_tokens += token_count
Original line (line 115)
f" | Input-tokens:{step_log.input_token_count:,} | Output-tokens:{step_log.output_token_count:,}"
Fixed version - add None handling
f" | Input-tokens:{step_log.input_token_count or 0:,} | Output-tokens:{step_log.output_token_count or 0:,}"
"Error in generating model output:
401 Client Error: Unauthorized for url: https://router.huggingface.co/hf-inference/models/Qwen/Qwen2.5-Coder-32B-Instruct/v1/chat/completions (Request ID: Root=1-680a7e9b-5c2059aa6ca44bed59bec0bc;6c8ff9c7-6358-4d3f-bf84-f596010c2321)
Invalid username or password. Error generating answer"
How to fix this error ?
updated the requirements file with smolagents
still same error
Fixed the previous problem,
Now
Invalid username or password."
Based on this error message, it is possible that the token content is incorrect or that the token you are passing is different from the token that is actually being passed.
The most reliable method is to use login(), but in many cases, the issue can be resolved by configuring the HF_TOKEN environment variable (Secrets).
Hello @sabler I have paid for the Pro, still I am getting the error. Created a new token as well. What Permissions did you end setting for the token so that it could work
If you are unsure about token permissions, using a READ token makes it easy. Also, it seems that the key operation when copying and pasting may be the cause.
The token I’m using is set to WRITE, but like @John6666 said, you should be able to use READ just fine.
Hello @John6666 and @sabler
I have given write permission for the token, tried to recreate the token twice, but was not able access the model. Still getting 402 error.
401 errors are often caused by mistakes or malfunctions, but 402 errors are usually caused by exceeding the monthly usage limit.
